Author: Subject: Quick K series answer needed
DIY Si
posted on 18/8/10 at 04:17 PM Reply With Quote
Evening all,
I've just spotted an engine on Ebay that is described as having noisy tappets. Any idea how easy a fix this could/should be? Will it need new tappets, or just an oil change and a good thrashing to clear it through?
Any advice/hints/tips welcome!
Sun Tzu, The Art of War
Humbug
posted on 18/8/10 at 04:57 PM Reply With Quote
Can't help you with that specific question, but my K is a bit tappety on startup. Seems Ok on the move, though (or I just can't hear it any more!)
stevec
posted on 18/8/10 at 05:04 PM Reply With Quote
If it was me I would try to find one that has not got noises. It could be a can of worms. There must be loads of good uns about.
Steve.
jollygreengiant
posted on 18/8/10 at 06:03 PM Reply With Quote
When I worked on them, the first thing to do was lift the cam cover and have a look. Worn cams are obvious and will need changing. If just noisy due to oil flush and change then that will be obvious too, ie. no wear on lobes and nop wear or obvious signs on ANY buckets. Some times the buckets can become 'faulty' and this is usually manifested by a discolouration or 'blue-ing' of the cam face of the bucket. Solution, change the faulty bucket.
Your problem is that this is on ebay and therfore will be sight un-seen so it will be very much 'Buyer Beware'.
edit bit
And remember some people would not know a cam rattle from a Big End rattle.
hope this helps
[Edited on 18/8/10 by jollygreengiant]
nnrouty
posted on 18/8/10 at 06:07 PM Reply With Quote
Sometimes tapets can become noisy or start clicking when the oil is low.
But i would avoid any noisy engine.
As long as its fast.... i don't care
posted on 18/8/10 at 07:08 PM Reply With Quote
Originally posted by DIY Si
Evening all,
Not a VVC is it? The VVC mechanisms can wear and cause top end noise.
DIY Si
posted on 18/8/10 at 07:47 PM Reply With Quote
Evening all,
This one wasn't, but I do ideally want the VVC version.
Thanks all, I'll stay clear of this one, especially now it's gone past the cost of a couple of VVC on there already.
