nnrouty
| posted on 20/8/10 at 08:44 AM |
R1 Carbs to 1800 Zetec
Hi
Can anyone tell which is the best age of R1 (carbs) for a zetec.
Looking for a really simple setup using a megajolt ecu.
As long as its fast.... i don't care
austin man
| posted on 20/8/10 at 08:58 AM |
As log as they are carbs not really a problem I am running zx9 carbs on mine with no problems. Either way you will have to drill out the jets
whitestu
| posted on 20/8/10 at 09:18 AM |
Just make sure they have a throttle position sensor - I suspect all R1 carbs will have a TPS though.
Stu
nnrouty
| posted on 20/8/10 at 10:29 AM |
Has anyone used Bogg Brothers to set up R1 carbs?
Thinking about going to them for the manifold but wanted to know weather it would be worth sending carbs as well?
| posted on 20/8/10 at 01:01 PM |
Yep, worth ringing BB, they will tell you what is required. I suspect if your purchasing one of their manifolds they will want the carbs off you.
DRC INDY 7
| posted on 20/8/10 at 09:15 PM |
I had my manifold made by boggs they just ask what the carbs were off and made it to suit
they did ask if i wanted to send the carbs to them for cleaning and set up
I declined i do all my setting up
Puddle Dodgers Club
bob
| posted on 20/8/10 at 09:31 PM |
I sent my fireblade carbs to boggs and they sorted the jets/needles.
Then sent carbs and new manifold back,top service from steve bogg.
