pekwah1
| posted on 23/8/10 at 09:21 PM |
xflow and throttle bodies (again)
Hi guys,
Sorry for the noob question, but i'm just wondering, if i put webers or simliar on my xflow, do i need some kind of management system
(megasquirt etc) or will will it run/can be adjusted without needing this?
Regards,
ANdy
stevebubs
| posted on 23/8/10 at 09:38 PM |
webers are carbs, so they just need to be setup with the right chokes, jets etc...
pekwah1
| posted on 23/8/10 at 10:44 PM |
oh ok, so it turns out i really am stupid!
so if i ran twin webers, i'd just have 1 throttle body or 2, 1 for each pair?
snapper
| posted on 24/8/10 at 05:21 AM |
A. Weber is a twin choke carb 2 x webers = 4 chokes
B. A throttle body is just a tube with a butterfly valve, the fuel is delivered by injectors controlled by an ECU.
My VR6 engined Galaxy has 6 injectors but 1 throttle body
I think you have some basic confusion on terminologies
If you run fuel injection you will need an ECU such as Megasquirt to run the fueling, you could still use the distributor for spark, Webers or bike
carbs can be bolted on and used with just the original distributor but will need to be set up for best effect
[Edited on 24/8/10 by snapper]
I eat to survive
I drink to forget
pekwah1
| posted on 24/8/10 at 10:06 AM |
Thanks for the help, yes i was getting confused between throttle bodies and carbs for some reason....
I'm not planning on having any fuel injection, will just be running the dcoes.
Obviously with this i don't need an ECU.
One of these days i'll get my head around engines!
prawnabie
| posted on 24/8/10 at 10:12 AM |
Ive got twin 40 dcoes on my crossflow if you need any info send me a u2u.
Shaun
pekwah1
| posted on 24/8/10 at 10:17 AM |
thanks shaun, i've been doing some reading on carb tuning... i'll probably have a go at doing it myself when i get to that stage but
i'm sure i'll get it wrong, so when i do i'll make sure i give you a shout!
