JekRankin
| posted on 28/8/10 at 09:22 AM |
Diff cover threadlock?
'Morning folks,
Just a quick one - I took my diff cover off to confirm the ratio, and when I replaced it, I torqued up all the bolts to Ford's spec (53Nm I
think) but I didn't put any threadlock on them.
Should I be taking it back out of the car to get some loctite on the bolts?
Jek
| posted on 28/8/10 at 09:31 AM |
I wouldn't bother, there are shed loads of them to share the load and it's not like the back of the diff takes a load....
RAYLEE29
| posted on 28/8/10 at 10:14 AM |
get under there with a white touch up pen and mark them then you can regularly check they havent moved with a quick glance
Ray
Angel Acevedo
| posted on 28/8/10 at 12:00 PM |
Locost Threadlocker
As stated above, I don´t think you need threadlockr on them.
On a related theme, I use Nail Polish on bolts ans nuts that I don´t want to get undone but not that critical to warrant the use of threadlock.
Paul TigerB6
| posted on 28/8/10 at 12:54 PM |
So come on then - whats your favourite colour??
If you want to threadlock them, then simply take one out at a time and re-torque each one as you work around. Shouldnt take you to long anyway
JekRankin
| posted on 28/8/10 at 02:03 PM |
Cheers guys, I'll mark them up and keep an eye on them. I can still get access to a few of the bolts so I might undo them and put some thread
lock on them just be sure.
Jek
