Author: Subject: 2.0 Pinto flywheel size...
Dan.
posted on 5/9/10 at 08:57 PM Reply With Quote
Hi guys does anyone happen to know the flywheel size on a 2.0 pinto?
omega0684
posted on 6/9/10 at 05:08 AM Reply With Quote
i have one in the garage i will measure later for you
kj
posted on 6/9/10 at 07:10 AM Reply With Quote
215mm same as a late model 1.6 model, the early moel 1.6 is 190mm.
Think about it, think about it again and then do it.
DaveFJ
posted on 6/9/10 at 08:12 AM Reply With Quote
and weighs over 9kg IIRC
you can get a good few kilos shaved off there though (mine is now only 5kg )
Dave
omega0684
posted on 6/9/10 at 10:23 AM Reply With Quote
mine is 3kg!
DaveFJ
posted on 6/9/10 at 12:42 PM Reply With Quote
lightweight.....
Dave
Dan.
posted on 6/9/10 at 03:37 PM Reply With Quote
Thanks for the replies guys... the reason for the random question is I am fitting a pinto engine initially and using a T5 gearbox, post IVA I will be changing to a volvo T5 engine. I was just working out whether I should buy a T5 to pinto bell housing or not... it would appear that the best option is for me to get a standard cosworth bell housing as the cosworth flywheel is the same diameter to that on the volvo so the starter motor should work nicely... will just have to make a temporary modification whilst the pinto is fitted.
