MakeEverything
| posted on 7/9/10 at 06:24 PM |
What Radiator is this?
Does anyone know what radiator this is please? I want to replace it with the same or something the same size at least. It has two plastic dimples on
the bottom for mounting, and two on the top under the tube that is in the picture.
  What Rad?
  Rad Height
  Rad Width
Kindest Regards,
Richard.
gavin174
| posted on 7/9/10 at 06:27 PM |
looks like a polo rad to me.
omega0684
| posted on 7/9/10 at 06:35 PM |
thats not a polo rad, inlet and outlets are on the same side on the polo rad i think
RichardK
| posted on 7/9/10 at 06:40 PM |
You are correct, not a polo, but dont know what it so not being helpful am I.
Sorry
Rich
Gallery updated 11/01/2011
gavin174
| posted on 7/9/10 at 06:44 PM |
you're right I stand corrected..
sorry its not a polo rad.
dhutch
| posted on 7/9/10 at 06:48 PM |
Cant really help, but its definitely not a polo/golf rad because as said, they have inlet/exit on the same side and also because they have parallel
ends not tapered.
Presumably no makers plate, part number, anything?
What is it made of, core and end caps? Is it ali or copper? Plastic ends or not?
Daniel
MakeEverything
| posted on 7/9/10 at 07:09 PM |
ends not tapered.
Daniel
I think the fins are copper, but it has been painted! The end caps are plastic.
No manufacturers plate or part number.
Kindest Regards,
Richard.
Mark Allanson
| posted on 7/9/10 at 07:32 PM |
I would say a modified Micra K10, the filler is missing as you would if using a header tank.
MakeEverything
| posted on 7/9/10 at 08:55 PM |
I dont think its modified as the caps are plastic. Also, on the micra rads, the mounting studs are on the plastic caps, not the rad itself like mine.
Kindest Regards,
Richard.
Chippy
| posted on 7/9/10 at 10:17 PM |
Take it to your local rad repair shop, they will tell you straight away, may even do it with just a photo. I did it with an old rad that I had
obtained, they told me and it cost £160 for a new one, Cheers Ray
MakeEverything
| posted on 8/9/10 at 08:33 AM |
I just found out that this is a Maestro Radiator!!!!
Holy shit!
Kindest Regards,
Richard.
Xtreme Kermit
| posted on 8/9/10 at 07:24 PM |
Wow!
Stick it in a museum - quick...
Mark Allanson
| posted on 9/9/10 at 08:25 PM |
Please Sir, whats a Maestro?
bob
| posted on 10/9/10 at 11:20 AM |
http://en.wikipedia.org/wiki/Austin_Maestro
