Author: Subject: Recent acquisition (diff)
Charlie_Zetec
posted on 27/9/10 at 07:27 PM Reply With Quote
Well, after loaning a friend my LSD to put in his Westie whilst my build took shape (his old one was knackered), i've finally sourced a replacement.
eBay diff linky
Looking at the eBay link, I've suddenly been overcome with post-winning stress. It occurred to me that I never actually asked the seller what ratio it was. I need a 3.62lsd to match up to my pre-programmed DD2 Lite digidash.
So, ever-hopefull, I e-mailed the guy asking for codes to check the ratios on the sticky thread in the transmission section. This is the reply I received.... "Hi, when i removed th back plate i miss placed the tag so i dont know the ratio sorry, the only numbers i can see are 83804026be 78084 hope this helps". Can anyone tell me what ratio it might be? I'd be amazed if it was a direct match to my requirements, but even so I can still find a use for it somewhere no doubt.
All input greatly received!
mcerd1
posted on 27/9/10 at 07:31 PM Reply With Quote
its writen on the crown wheel if he's had the the back plate off....
most of the 7" LSD's are 3.62's and if its not I sure someone else will want it
snapper
posted on 27/9/10 at 07:37 PM Reply With Quote
90% sure it Will be a 3.6 most are but it it is a 3.9 a swap would be easy.
If it is any other ratio your in the money
I eat to survive
I drink to forget
posted on 27/9/10 at 07:38 PM Reply With Quote
for £100 it doesnt matter if its the wrong ratio, you'll not lose money on it. But nearly all are 3.62 anyway.
zetec mike
posted on 28/9/10 at 12:18 AM Reply With Quote
3.92 LSD on ebay
If you need a 3.92 lsd theres one on ebay.
http://cgi.ebay.co.uk/SIERRA-4X4-DIFF-LSD-KIT-CAR-MK-INDY-3-92-RATIO-AXLE-/270640595187?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f036fc0f3 r />
[Edited on 28/9/10 by zetec mike]
zetec mike
posted on 28/9/10 at 02:57 PM Reply With Quote
If you're running a zetec you might find the 3.6 a bit too long, I would of thought a 3.9 or 4.1 would be more suited.
