Author: Subject: steel tubing for bushings
Johneturbo
posted on 13/10/10 at 02:37 PM Reply With Quote
i've been looking into using polybushings for mounting my ZZR14 engine
from here http://www.energysuspensionparts.com/Energy-Suspension-Universal-Link-Flange-Type-Bushings.asp
but as it's from the US they use inches rather than mm
the size i'm after is 1 1/2 (38.1mm) inner dia with 3mm thickness, length isn't a problem oh-er as i can cut to fit
anyone know where i can buy such a size looked on ebay but they all state the OD not ID
40inches
posted on 13/10/10 at 03:27 PM Reply With Quote
Wall thickness x 2 + I.D= O.D = 1 3/4"x1/8" or 44mm x 3mm ish
Johneturbo
posted on 13/10/10 at 05:09 PM Reply With Quote
ahhhh simple enough when you break it down like that
not had much luck with the size i need thou
Chippy
posted on 13/10/10 at 10:06 PM Reply With Quote
What you need is 1 3/4" x 10gauge tube. Not sure if they make tube that size, but worth a punt round. HTH Ray
daviep
posted on 13/10/10 at 11:14 PM Reply With Quote
1.5"(nominal bore) schedule 80 pipe is 1.5" ID and 5mm wall
Davie
Johneturbo
posted on 14/10/10 at 04:22 PM Reply With Quote
i have found a place that does 1 3/4 X10 gauge
which if i'm right and going by the formula
is 44.5mm - 3.2 10 gauge = 38.1 = 1.5"
just don't know if i have to buy a shipment full! i only need 6x 1.9" lenght
