Author: Subject: 1600 zetec fly wheel problem
Duncan Mould
posted on 14/10/10 at 08:38 PM Reply With Quote
I currently have a 928M6398AG flywheel on a 1600 zetec block LIH YK68275 is this correct? Ford say it should have a 928M6K390 fitted to that engine. Whats the difference? There was no fly wheel fitted to the engine when I got it and the breakers sent this one. Having all kinds of problems at low revs, suspect CPS as the drillings may be in different spots?
Is their any Ford men out there that can confirm my babblings.
whitestu
posted on 14/10/10 at 08:56 PM Reply With Quote
I'd be surprised if the drillings were different. They are the same between 1.8 and 2.0 Zetecs.
Stu
big_wasa
posted on 14/10/10 at 09:15 PM Reply With Quote
1.6 is the same as the 1.8 and all three use the 36-1 pickup.
There is no Immobilizer set up in the flywheel like Rover /Mg's
Have you looked at the cam timming / checked it with a Timming kit.
Its a 5mm plate that holds both cams and a pin that holds the crank.
austin man
posted on 14/10/10 at 09:21 PM Reply With Quote
Check cam timing first, The sensor may need cleaning or could it be that an automatic sensor is being used these ar different sizes I belive so potentially will affect the ability to pick up the signall effectively
Duncan Mould
posted on 14/10/10 at 09:28 PM Reply With Quote
sound advice will give it a go tomorrow.
big_wasa
posted on 14/10/10 at 09:36 PM Reply With Quote
Should tell you one way or another.
[img][/img]
