snapper
| posted on 17/10/10 at 10:22 AM |
Oil sender conundrum
I have a new oil cooler take off with built in thermostat, this has removed my oil temp sender from an inline adaptor, I now need to relocate it.
The standard oil pressure take off in the block has the standard oil pressure light switch and oil pressure sender off a straight adaptor.
The sump is a modified RS2000 with a metric M12 plug.
The current oil temp sender is either 5/8 unf
I don't mind buying another sender and or some adaptors but am lost as where to go next?
Any ideas?
[Edited on 17/10/10 by snapper]
I eat to survive
I drink to forget
will121
| posted on 17/10/10 at 11:15 AM |
i fitted mine into a sump plug as link, only thing is may need to change to a 1/8 NPT sensor
SUMP PLUG ADAPTOR M12 M14 M16 M18 M20 M22 1/8 NPT on eBay (end time 22-Oct-10 18:23:10 BST)
Paul (Notts)
| posted on 17/10/10 at 11:52 AM |
same idea
https://www.burtonpower.com/product_main.aspx?dets_product.aspx?PSet=97&sTxt=lma064
snapper
| posted on 17/10/10 at 12:40 PM |
Thank you both, the sump plug and new 1/8" npt sender is the way I will do it.
I eat to survive
I drink to forget
RazMan
| posted on 17/10/10 at 03:56 PM |
Won't the sender make ground clearance an issue - I mean the sump is usually the lowest point on a CEC (it certainly is on mine)
Raz
