MikeR
| posted on 20/10/10 at 09:24 PM |
Making an inlet - how thick should the steel be?
I've been looking at making my own inlet recently. I've found some people who'll do an inlet flange for me to weld to. One person
does a 6mm flange, the other 8mm.
Obviously the thicker the better to reduce distortion on welding but .... the 8mm is more expensive and heavier.
How thick is your inlet / how thick do you think it should be? It will have 1.5mm steel welded to it.
Finally - anyone want to convert crossflow weber carbs to fuel injection with a new manifold?
(guess what my current plan is before i do the same for silvertop and then make a complete silvertop inlet manifold reusing all the zetec parts).
| posted on 20/10/10 at 09:32 PM |
If you can bolt it to the head whilst welding it up then I'd be inclined to go for 6mm in steel myself
Miks15
| posted on 20/10/10 at 10:04 PM |
mine is 6mm, as said make sure it is bolted to something solid, and take time welding it, mine got a tiny bit distorted, but not enough to ruin the
seal.
but that was without bolting it donw (dont you love hindsight!)
will121
| posted on 20/10/10 at 10:40 PM |
mine was 6mm steel as above it distorted a bit by bowing from the middle about 3mm, but just put in the vice and gave it a tug with aid of an
adjustable spanner for added leverage and came back flat. i done bit of a guide with lots of pictures if it helps.
zetec inlet manifold guide
MikeR
| posted on 20/10/10 at 10:41 PM |
Bolting to the cylinder head isn't an option - i want to make a jig so i have the option of making a few if other builders are interested. It
may get bolted to another inlet manifold as part of the jig - but that increases my initial setup cost (and i'm out of work).
splitrivet
| posted on 20/10/10 at 10:48 PM |
Last one I made I made a new inlet gasket from 2mm cork to compensate for any warping etc.
Bob
madteg
| posted on 21/10/10 at 06:08 AM |
Tack it to heavy bit of steel weld it up and then break tacks, clean tack of job done.
dhutch
| posted on 21/10/10 at 07:36 AM |
And if its really bad, you can always get someone to take a skim off it.
