danj8608
| posted on 28/10/10 at 08:11 PM |
1.8 zetec on bike carbs
Im new to the forum and i want to fit bike carbs to my 1.8 zetec engine im fitting to my escort van.
Is there any guides or how to's on the subject so i can read up on
many thanks Dan
austin man
| posted on 28/10/10 at 08:14 PM |
fitting bike carbs or bike throttle bodies there is a difference in what you will need to run it and if injection it will need mapping
danj8608
| posted on 28/10/10 at 08:18 PM |
obviously the cheaper bike carb conversion is what im after, then progress at a later date
interestedparty
| posted on 28/10/10 at 08:34 PM |
It's not obvious at all.
If your van is subject to post 93 emissions test at MOT time then I doubt if you are going to pass with the engine on carbs.
danj8608
| posted on 28/10/10 at 08:38 PM |
the engine is from a 92 xr3i 130
snapper
| posted on 28/10/10 at 08:44 PM |
Bike carbs don't like to much fuel pressure, it is recommended to fit a bike fuel pump or a fuel pressure regulator such as a Malpassi filter
king.
You will need a manifold made up and don't forget the vacuum take offs for the servo.
Throttle cable linkage is usually fairly simple, just cut off the original cable end and use a screw on nipple.
Choke cable may need re routing
I eat to survive
I drink to forget
austin man
| posted on 28/10/10 at 08:47 PM |
converting to carb is simple really have a manifold made to suit your carbs (ZX9's are okay) buy an ecu Megajolt, find an EDIS unit make a loom
and fit simples.
Or Buy my twin webbers GEMS ECU Fuel Fump, Regulator, wiring loom and Manifold all set up for a 1.8 zetec before I split and put them on ebay
danj8608
| posted on 28/10/10 at 08:55 PM |
price ?
austin man
| posted on 28/10/10 at 09:09 PM |
£300 plus p&P set of K&N filters as well
| posted on 28/10/10 at 09:15 PM |
Welcome Dan, bike carbs on a 1.8 zetec is dead easy. All you need is a set of carbs and a Megajolt.
Then manufacture an inlet to suit the carbs and your there with 165bhp.
Check my blog below as that's how I got my 7 build and through SVA.
Ignition can be found through an early Ford ecu if you have the right information.
If you need any more info give me a shout (u2u)
Regards,
alawrence
| posted on 28/10/10 at 09:43 PM |
u2u sent re some comments above
[Edited on 28/10/10 by alawrence]
danj8608
| posted on 29/10/10 at 05:14 PM |
Regards,
Thanks for the welcome just had a look on ebay for a megajolt kit and this is what i have found.
Complete Megajolt 3D ignition system for Zetec engines on eBay (end time 03-Nov-10 06:26:14 GMT)
would that be the one i should be getting ?
Another question, what bike carbs will be best suited for my engine.
Thanks Dan.
cliftyhanger
| posted on 30/10/10 at 10:45 AM |
you should buy my megasquirt setup, will do all the megajolt will do plus it does fuel injection and comes with TB's etc. Bolt on, map it and
done, more or less!
slightly tongue in cheek. Do not assume mapping fuel injection, or indeed setting up bike carbs, is as easy as many would have you believe. Not unkown
for people to kill their engines when things go all weak and melt pistons But it can be done, would always want to use a lamba sensor to check, or
have a session on the rollers.
| posted on 30/10/10 at 11:19 AM |
Regards,
Thanks Dan.
That is the Megajolt who need, however I think you may find it cheaper elsewhere on the www. If you can solder theres kits available from the
states.
This is the site for the peeps who developed it:
http://www.autosportlabs.net/MegaJolt_Lite_Jr._-_A_DIY_Programmable_EDIS_Ignition_Controller_-_Users_Welcome!
Tons of info there.
Re: carbs, I would go for ZX9R, get the ones with the TPS on them ZX7R are alos the same or even ZZR1100. These all have 40mm chokes and work well on
a zetec. I recommend these as thats what me and the other lads round here use with great success.
I bought mine off ebay and the passed SVA without any jetting. Set up later by Bogg Brothers they gave excellent power and economy.
[Edited on 30/10/10 by coozer]
lotusmadandy
| posted on 30/10/10 at 07:04 PM |
Yup,
I've got zx9r's on a homemade manifold and megajolt on my 2.0 zetec.
As said by Coozer they are used,with great success by a few of us round here.
FASTdan
| posted on 31/10/10 at 01:05 PM |
Zx9's are great, fuel our 2.3 duratec very well :-)
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
FASTdan
danj8608
| posted on 31/10/10 at 08:44 PM |
i have bought one of your inlet plates
danj8608
| posted on 31/10/10 at 08:51 PM |
I think ill treat myself around xmas time and buy a complete setup thats ready to fit.
So if any of you lot have what id need and are willing to sell the set up around the 26th of nov send me a msg and ill buy it
Dan
