Author: Subject: Fuel sender
kylerichmond
posted on 31/10/10 at 07:39 AM Reply With Quote
Fuel sender
Doe anyone know which fuel sender unit would i use in a robin hood 3A fitted with sierra clocks?
whitestu
posted on 31/10/10 at 08:02 AM Reply With Quote
Are you building the car or replacing the sender?
If the latter, can you post a pic of the existing one?
I would have thought if Sierra clocks are being used a Sierra sender would be most likely.
Stu
snapper
posted on 31/10/10 at 08:28 AM Reply With Quote
Robin Hood used a standard sender, outlet and return/breather, 1 wire type.
This works with the Sierra gauges but can be modified to work with aftermarket Euro spec ones.
GBS Kit parts direct do them for about £15.
sealing them is a little difficult, I used 3mm cork and spread the clamping load with bars across two bolts
I eat to survive
I drink to forget
RichardK
posted on 31/10/10 at 03:58 PM Reply With Quote
Ive got a standard sierra fuel sender kicking around if its any use to you.
Rich
Gallery updated 11/01/2011
