pekwah1
| posted on 4/11/10 at 10:44 PM |
can i use the standard zetec clutch?
As above, running an 1800 zetec silvertop mated to a type 9, can i use the standard 1800 flywheel/clutch setup?
Had a search but not finding anything....
andy
austin man
| posted on 4/11/10 at 11:00 PM |
Im using it with no problems initially had the standard sierra release bearing with no problems but then read that it will run out of travel not
allowing further adjustment, The recommended bearing is from a Ford Capri cant recall the number. This bearing is longer on the shaft than the sierra
one
pekwah1
| posted on 4/11/10 at 11:01 PM |
what i wanted to hear, thanks very much!
Dusty
| posted on 5/11/10 at 12:45 AM |
Bearing is Quinton Hazel CCT133.
femster87
| posted on 5/11/10 at 08:58 AM |
i have just bought the transit releasr bearing cct 303. would this work as well
pekwah1
| posted on 5/11/10 at 09:00 AM |
do some searches on here for "release bearing", sounds like the 133 is the one to go for, the 303 might not give enough travel due to it
being smaller...
femster87
| posted on 5/11/10 at 09:26 AM |
Ah problem solved. I am using the standard 2.0 flywheel. therefore the 303.
macc man
| posted on 5/11/10 at 05:48 PM |
Just a reminder that a spigot bearing will need to be fitted to the end of the crankshaft.
This will support the gearbox input shaft preventing wear. Ford Part no FINIS 1554973.
