Trev Borg
| posted on 6/11/10 at 11:18 PM |
Type 9 cad drawing or at least measurements
Looking for the dimension for the bellhousing for a type 9
looking to fabricate an bespoke bellhousing and would like accurate measurements.
So, if anyone has access to these, it would be nice
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
snapper
| posted on 7/11/10 at 05:08 AM |
I have a Ford technical drawing of box only U2U me an email and will send it when I get to work Monday
I eat to survive
I drink to forget
lochraceness
| posted on 21/5/11 at 11:49 AM |
I don't know if this is the correct way to do it, but I'll give it a shot (thought it might be better to use an old thread instead off
starting a new):
I'm looking for the exact same thing as the original poster was looking for... drawings with measurements of the Ford Type 9 gearbox. I might
also be interested in the very same for the Type E gearbox. It is going to be used for modifying a bellhousing in order to connect a Mi16 XU9J4 engine
to the gearboxes.
If anyone has this and might be willing to share, I'll be very happy. Thanks, lochraceness
| posted on 21/5/11 at 12:09 PM |
Be aware that there are at least 2 bellhousings for the type 9, the 4 cylinder and the v6 , the diesel may be the same as the v6?. The gearbox input
shaft is also a different length
lochraceness
| posted on 21/5/11 at 01:01 PM |
Thank you for your reply.
Do you know if the box itself is different other than the shaft length? I'm going to use a bellhousing from an LDV Pilot van which need to be
milled down a bit because the shaft is too short. What I really need is a drawing with measurements that shows the face of the box where the original
bellhousing normally sits... I need this in order to make a spacer that fits both the bellhousing and the box.
I actually have both a type E gearbox and a type 9, but I believe the face where the bellhousing sits are the same on both boxes. As far as I've
been able to work out the length of my type E shaft is 176mm from the face of the box. I think I wish to use this box because it's a 4 speed and
I'm going to use it for racing purposes.
Please let me know if you would like me to start a new thread on this subject. Thanks.
Cheers, lochraceness
| posted on 21/5/11 at 06:41 PM |
The V6 and the diesel use the longer shaft which may be about19mm longer , the diesel box doesn't have very good ratios though
