Fishface
| posted on 16/11/10 at 01:10 PM |
cortina live axle seal
Does anyone have details how to change the oil seal on the cortina axle where it the propshaft connects?
| posted on 16/11/10 at 01:27 PM |
Not done a Cortina one specifically, but the general method is...
1. Brace input flange with a bar bolted to it.
2. Remove nut from input shaft (might be staked).
3. Remove input flange from input shaft (might need a puller).
4. Pry out the old seal carefully (large flat screwdriver usually works).
5. Lightly grease the new seal and knock in square using a drift (blocks of wood help) to protect it.
6. Refit input flange and nut to correct torque.
Away you go!
[Edited on 16/11/10 by nick205]
big_wasa
| posted on 16/11/10 at 05:48 PM |
Changing it isnt hard but it is critical that you dont over or under tighten the nut on refiting or you will alter the backlash in the cwp and bugger
the lot.
It was suggested to me that you count the number of turns to undo it and do it back up my the same amount.
