Kriss
| posted on 16/11/10 at 06:26 PM |
sierra Lobro driveshaft cv diagram explination
Yo, hope you are all well.
Can anyone show me how to take apart the diff end of a driveshaft to I can fit a new cv boot? Understand there is a circlip to be deskt with but I
need to know exact location as will have the hub end still attached if possible that way.
snapper
| posted on 16/11/10 at 06:35 PM |
Once you unbolt from the diff, look at the joining face off the lobro, clean out the grease from the shaft and you will see the circlip
I eat to survive
I drink to forget
omega0684
| posted on 16/11/10 at 06:53 PM |
remove the circlip and the lobro will just fall off, clean it up and then put your new boot on the shaft. replace the cv jpoint and the retaining
circlip, the just fasten the boot to the shaft and cv joint (dont forget to put new cv grease in)
its that EASY!
matt_claydon
| posted on 16/11/10 at 07:26 PM |
  Lobro circlips
One circlip either side of the joint as shown if I remember correctly. You only need to take the outer one off to remove joint and fit new boot.
