Author: Subject: exahaust spacing
blakep82
posted on 16/11/10 at 09:40 PM Reply With Quote
exahaust spacing
following my problem of the exhaust hitting the gearbox, i've got another flange for this engine, but didn't quite fit the pipes, but will work fine as a spacer, its not the way i'd like to do it, but whats the thoughts on using this as a spacer with a gasket between the engine and spacer, and one between the the spacer and exhaust flange?
i tried and it just fits, but i'd need longer exhaust studs (or bolts?) this would only be temporary thing til the car's on the road and i get get the car to someone who can mod it further and get it right. would be ok wouldn't it?
________________________
prawnabie
posted on 16/11/10 at 10:25 PM Reply With Quote
I did it on my crossflow to space the manifold away from the starter, was 20mm iirc - never had any problems in the 2 years it was like it.
Shaun
FASTdan
posted on 17/11/10 at 07:35 AM Reply With Quote
Likewise we ran a 30mm alu spacer on our pinto head with gasket either side, ran it for 12 months, 3000 miles like that, never blew, just had to keep an eye on the bolt torques for the first few months as the gaskets settled in. It was to space the manifold off our slightly different/wider bodywork.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
speedyxjs
posted on 17/11/10 at 10:55 AM Reply With Quote
It should be fine
[Edited on 17-11-10 by speedyxjs]
blakep82
posted on 17/11/10 at 02:25 PM Reply With Quote
awesomeness thanks
so longer studs or bolts for the exhaust then?
