Author: Subject: Need torque specs for a KENT
mangogrooveworkshop
posted on 24/11/10 at 07:11 AM Reply With Quote
need the following
Big ends small ends and head bolt oh and the flywheel bolt.
How much tightyness to make them.... any other info would be good
contact lomoss or u2u him
Confused but excited.
posted on 24/11/10 at 01:19 PM Reply With Quote
The Gospel accordning to Haynes.
Main bearing caps: 55 - 60ft/lbs
Big ends: 31 - 35 ft/lbs
Cylinder head bolts: 5ft/lbs, then 20 - 31ft/lbs, then 52 - 56 ft/lbs, wait ten to twenty minutes, then 66 - 71ft/lbs, finally warm up engine; 15 minutes @1,ooo rpm then re-tighten to 66 - 71ft/lbs.
Flywheel: 55 - 56ft/lbs.
HTH.
[Edited on 24/11/10 by Confused but excited.]
