designer
| posted on 1/12/10 at 11:27 AM |
Cheap oil catch tank
Seem like a good deal.
Universal High Quality Aluminum Oil Catch Can Tank Blac on eBay (end time 10-Dec-10 07:51:12 GMT)
Bluemoon
| posted on 1/12/10 at 11:36 AM |
Awaiting ali drink bottle reply for a pound..
MikeR
| posted on 1/12/10 at 11:44 AM |
Bear in mind its size ........... its width is 2 1/4" or 56mm & height is 5.1" or 12.5cm. Total volume is just over 300ml, or less
than a can of coke.
Its a little bit tiny - although i suspect big enough if your car doesn't breath much and you keep your eye on it.
dhutch
| posted on 1/12/10 at 01:04 PM |
I didnt even do that, used rc car fuel tin on one, and a used junk tin on the other.
andylancaster3000
| posted on 1/12/10 at 02:16 PM |
Agreed. I go by the thinking that catch tanks shouldn't cost you anything!
FYI, the MSA suggest that a catch tank should be at least 2litres. I've managed to over fill one at that size too! (don't ask )
[Edited on 1/12/10 by andylancaster3000]
| posted on 1/12/10 at 02:27 PM |
That is absolutely tiny, it would be waste of time fitting it to anything that actually needed it.
Volvorsport
| posted on 1/12/10 at 04:05 PM |
ive used header tanks i the past with good success .
www.dbsmotorsport.co.uk
getting dirty under a bus
trikerneil
| posted on 1/12/10 at 05:33 PM |
I'm using a Boddingtons can.
Neil
ACE Cafe - Just say No.
jacko
| posted on 1/12/10 at 07:13 PM |
I use a old oil spray gun can And the best bit is you can take the lid off and wipe the old scummy oil out
Jacko
