Jumpy Guy
| posted on 22/6/04 at 03:35 PM |
Plumbing - how do I neatly terminate all the unused water pipe bits?
excuse the technical terms! at present i have a wee bit of hose, doubled back on itself with a bar clamp, but its not very tidy...
suggestions?
ned
| posted on 22/6/04 at 03:36 PM |
cut the tubes right back and insert a bolt with a jubilee clip tight round it?!
Ned.
beware, I've got yellow skin
James
| posted on 23/6/04 at 12:03 AM |
Exactly as Ned says- except I coated the thread of the bolt in a waterproof silicon sealant first.
James
EDIT: I've used stainless bolts for this.
[Edited on 23/6/04 by James]
zetec
| posted on 23/6/04 at 08:27 AM |
If you can get a end stop copper fitting or a piece of copper tune with the fitting soldered on and jubilee clip that works well. Get a Yorkshire
fitting and it will have a ready made flange, paint it black job done.
| posted on 23/6/04 at 09:38 AM |
Terminator 2.
It's called blanking in plumbing terms Jumpy . Doesn't have the same ring to it for a movie title though.
Terrapin_racing
| posted on 23/6/04 at 03:07 PM |
I'm fussy - I prefer to cap the outlets at source rather than stop end a hose. A little effort makes the job look so much better. Capping may
involve a plate, a threaded bung or welding. These are available to buy from motorsport manufacturers etc. but invariably you end up making your own
