Author: Subject: zetec ignition timing - how to check
andy188
posted on 21/12/10 at 07:46 PM Reply With Quote
Hi, looking at fitting megajolt to my 2.0l, as an upgrade to to my esc, im an old school engine person, pinto, cvh etc, how do i go about checking my ignition timing, as i used the my old cvh front pulley, and mounted the pick up on a bracket, on my zetec as the engine i bought was from an auto. have heard you can check it with a timinig light, how do you go about this, where are the pionters etc, anybody got a base map for megajolt i can use for the zetec on bike carbs, many thanks.
austin man
posted on 21/12/10 at 08:08 PM Reply With Quote
have you fitted a manual box with the zetec flywheel if so all you need is the standard pick up sensor it would be spot on with the timing
RichardK
posted on 21/12/10 at 11:10 PM Reply With Quote
Without the megajolt powered up the ignition will be in limp home mode, which means the ignition wont advance as the revs increase, so you can check this with a timing light and rev the engine and it shouldn't change, try again with the megajolt powered up and the ignition marks should move about as the revs change.
Not sure where the timing marks are on a zetec but should be in the haynes books. I'll be doing this exercise in the next few weeks! You'll need a timing light that isnt affected by the wasted spark btw.
Hope this helps
Rich
Gallery updated 11/01/2011
AndyW
posted on 22/12/10 at 04:18 PM Reply With Quote
I seem to remember that there are no timing marks on a 2.0 zetec. You have two "5mm" slots in the camshafts to lock them into position, and a removable plug in the block so you can insert a tool to lock the crank at TDC. But if I am wrong then I apologise.....
Mal
posted on 22/12/10 at 05:58 PM Reply With Quote
The basic timing on a Zetec engine can't be wrong because one of the flywheel to crank bolts is slightly offset and the position of the crank sensor is fixed.
RichardK
posted on 23/12/10 at 06:09 PM Reply With Quote
Ah, ok so it'll be as I said as above but to check if the megajolt is working is to significantly adjust one of the settings and listen for a change in the idle speed etc.
Rich
