AdrianH
| posted on 21/12/10 at 08:30 PM |
Are 1.8l Zetec Silvertop and Blacktop flywheels identical?
I am just working out clutch options to a type 9 and looking at the Mondeo engines noticed the Silvertop had a clutch which is 220 mm diameter with
splines of 25.4 mm x 23. The Blacktop is 210 mm diameter with splines 26 mm x 23.
I have the latter engine from the mark II mondeo and I am just wondering if the flywheel would take the earlier larger clutch?
I did a quick check with my Sierra clutch basket (CVH) and found the mounting holes are different and would not fit and that's off a 215 mm
diameter clutch.
Adrian
[Edited on 21-12-10 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Dusty
| posted on 21/12/10 at 11:37 PM |
If you buy the silvertop 1.8 flywheel it will bolt straight onto the blacktop crank. And it's drilled to fit the silvertop clutch. Or get your
blacktop flywheel drilled to accept a pinto clutch which will take more power than the zetec ones.
whitestu
| posted on 22/12/10 at 08:37 AM |
You could always use th CVH flywheel which is miles lighter than any of the Zetec ones. That's what I did. Just needed the flywheel bolt holes
opening up and a trigger wheel on the front crank pulley.
Stu
AdrianH
| posted on 22/12/10 at 07:12 PM |
I can see a U2U with lots of questions from this answer!
Adrian
