| posted on 23/12/10 at 04:04 PM |
repairing an intercooler
hi all.
ive got a split intercooler on a merc sprinter, its come apart where the plastic joins the ally bits. Is it repairable do you think? Lather in
silicone and see what happens?
It only needs enough of a bodge to get it sold #
Cheers!
PSpirine
| posted on 23/12/10 at 04:08 PM |
Got a photo?
speedyxjs
| posted on 23/12/10 at 04:21 PM |
How about some chemical metal stuff? THat sticks to plastics and should be a more perminant bodge?
ashg
| posted on 23/12/10 at 04:26 PM |
Black tiger seal pu adhesive would be my weapon of choice. Silicone is a sealer not a glue
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
blakep82
| posted on 23/12/10 at 04:32 PM |
silcone would cause the lamda sensor problems wouldn't it? if diesels have one. i'd go with chemical metal/epoxy resin type stuff
________________________
PSpirine
| posted on 23/12/10 at 04:38 PM |
If it's a join where it was originally glued together (plastic to ali), black tiger seal as mentioned. OEM recommended for fixing anything to
anything that doesn't have a nut bolt or rivet.
If it's a crack or hole in the plastic, either weld it or chemical metal - depending on the type of plastic. When I say weld, I do mean graft by
melting with a soldering iron.
PAUL FISHER
| posted on 23/12/10 at 04:51 PM |
On that type of construction of intercooler with the plastic end cap, it is common for them to split apart, tuning companys use the plastic banding
that you use on packing crates etc when they do boost upgrades on this type of intercooler to hold them together under increased boost, so you could
try a combination of silicon sealant and the banding if you know anyone with one.
carpmart
| posted on 23/12/10 at 04:52 PM |
Think of the poor unsuspecting person (like you or me) who is buying it in good faith! My response would be repair it properly!
Indecently, a proper repair could be the black gunk!
[Edited on 23/12/10 by carpmart]
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
| posted on 23/12/10 at 05:42 PM |
cheers all!
its a £1000 van so i dont want to spend £70 on a new intercooler, because loads of other bits need sorting too!
| posted on 23/12/10 at 07:01 PM |
Araldite
Moorron
| posted on 23/12/10 at 09:53 PM |
this happens on the Renault 5 turbo intercooler when upping the boost. Job is to seal it with silicone and then fit a huge jubilee clip around it.
[Edited on 23/12/10 by Moorron]
Sorry about my spelling, im an engineer and only work in numbers.
