Author: Subject: Duratec Oil Pressure Sender
Tiger Super Six
posted on 24/12/10 at 09:10 AM Reply With Quote
Chaps,
What are the options of where the oil pressure sender can be fitted on the Duratec?
Mark.
Mark
Tiger Avon
redeye
posted on 24/12/10 at 09:38 AM Reply With Quote
Oil Filter Housing
This is the option ill be goin for
http://www.raceline.co.uk/products/part_section.asp?SectionID=18&CategoryID=1
Will give more clearance for the oil filter and has two takes off for the likes of Oil pressure
hope this helps
Patrick
Tiger Super Six
posted on 24/12/10 at 09:45 AM Reply With Quote
That's what I bought but my sender thread doesn't fit it, wondered if there was anything in the block that could be used instead?
Mark
PS - If not I will speak to Chris to see if there is an adapter that will fit the sender and then then housing.
Mark
Tiger Avon
redeye
posted on 24/12/10 at 10:12 AM Reply With Quote
I would have thought some kind of adaptor would be available.
Hows the install going anyway?
I havent done much to my engine since I bought it, I plan to rebuild it over january before fitting tho.
Have you sourced a bellhousing and any other parts yet?
What are you planning to do for induction and engine management?
Patrick
Tiger Super Six
posted on 24/12/10 at 10:35 AM Reply With Quote
I had a nice raceline order turn up yesterday which was their sump, oil housing, water rail, inlet manifold (for webber 45's). Today I ordered the cable clutch bellhousing from RWD motorsport so will have a few days over Christmas fitting things
I am keeping webbers as the induction for the moment as I don't have a return fuel feed and I already have the webbers. I will then go OMEX with the ECU I think but not sure whether to buy the basic one for the webber set up or get one ready for injection as I might do that in a few years.
Still need to get alternator mounting kit, throttle position sensor, crank position sensor, lightened flywheel and clutch and then I think I will nearly be there.
Mark.
Mark
Tiger Avon
Tiger Super Six
posted on 24/12/10 at 10:37 AM Reply With Quote
PS - no it's not really lowcost I did a pinto to zetec swap on a previous car and did it cheap and then bought all the nice parts after, which costs even more. Decided to buy the bits I wanted straight away this time rather than double up on cheaper bits first just to get it in the car.
Mark
Tiger Avon
redeye
posted on 24/12/10 at 10:49 AM Reply With Quote
Bloody ell.....that cant have been cheap.
The Raceline stuff does look very nice tho
any particular reason for not goin for the hydraulic clutch?
I plan to fit bike throttle bodies with Omex ECU, Im a fan of webbers as I had these on my pinto, but I wanted to try something different with injection.
Did you engine not come with a crank position sensor already?
Keep us updated with photos and the like....always good to see new shiney engine bits
Patrick
Tiger Super Six
posted on 24/12/10 at 11:09 AM Reply With Quote
No, it's not cheap, but it is reliable and it looks nice
I didn't go hydrolic clutch as I fitter floor mounted pedals earlier this year (the 3GE ones) and it is a cable clutch. Apart from hacking a lot about it is easier to go the cable route and there is no real disadvantage that I can see. I would have liked to have gone injection but cant see the point of the additional cost given I have the 45's and would rather spend that money on other shiney parts.
The guy that took it out of the car had unbolted the crank position sensor and I threw it away by accident! not ideal, but I don't think they cost much.
Will post some pics when I get it fitted.
Mark.
Mark
Tiger Avon
