Author: Subject: Zx9r carbs fuel line size?
rich201283
posted on 28/12/10 at 09:54 PM Reply With Quote
On the zx9r carbs there is a t-piece with the inlet which is 10mm then that feeds through the other to 8mm pipe to the carbs.
Should i replace the t-piece so that all 3 outlets on the t-piece are all 8mm as i want to run a 8mm fuel line.
Will this be large enough for a 2ltr zetec????
RichardK
posted on 28/12/10 at 10:22 PM Reply With Quote
Yep, that is what I'd do, seems like a sensible solution.
Rich
Gallery updated 11/01/2011
posted on 28/12/10 at 11:10 PM Reply With Quote
It's all 8mm on my ZX9 carbs anyway, has someone swapped yours before? That's on a ZX9 engine as standard.
[Edited on 28/12/10 by Peteff]
rich201283
posted on 29/12/10 at 06:51 AM Reply With Quote
just found out on the earlier carbs the line was 10mm, Just gonna make it 8mm
jacko
posted on 29/12/10 at 09:54 AM Reply With Quote
On zx9r /e carbs they use 10mm in for fuel i used 8mm copper pipe from the tank to the front of my car then a 8-10 mm air line connector if this helps
Jacko
