lotusmadandy
| posted on 2/1/11 at 08:46 PM |
zetec info
Ok,here's a question for the house.
Does anybody know if the 2.0 zetec from a cougar is the same as one from a mondeo?
The reason i ask is i found a decompression plate on eblag but it is listed for a cougar.
All the info i have found on the web suggests that it is.
As always any help or info will be greatly received,
cheers,
andy
RichardK
| posted on 2/1/11 at 09:13 PM |
Crikey, what a question, I would say they are the same although slightly conflicting data from
here and
here although the difference in standard power could be down to fuelling??
Cock on the block time and I'll say yes...
(how much is it, if it all goes wrong )
BTW, the conflicting data was the engine code in the ad was for a cougar but says it was removed from a mondy...
Rich
[Edited on 2/1/11 by RichardK]
Gallery updated 11/01/2011
big_wasa
| posted on 2/1/11 at 09:25 PM |
Yeh same engine.
lotusmadandy
Thats the same conflicting info that i came up with Rich.
I would say yes as well,i just wanted someone else to say yes.
The plate is £43 and pennies delivered from germany.The next cheapest is £72 delivered.
Cheers Rich.BTW how's the conversion going?
And cheers Warren.I'll buy the plate tonight.
[Edited on 2/1/11 by lotusmadandy]
RichardK
| posted on 2/1/11 at 09:38 PM |
Going well mate, thanks for asking, just got my catch bottle mounted and aux belt fitted and messed about getting the idler pulley to work, just
waiting for my hoses to turn up and I can then get coolant in it and get it started.
Pictures in my gallery if you can be arsed...
Rich
big_wasa
| posted on 2/1/11 at 09:51 PM |
the engine code will be differant but its still a black top
ChrisW
| posted on 2/1/11 at 09:55 PM |
Sure you don't want to wait until I've checked mine, Andy?
Chris
lotusmadandy
| posted on 3/1/11 at 08:29 AM |
Yes Chris,I will wait until you get back to me.
He has got ten of them so i cant imagine him selling out
ptoyne
| posted on 4/1/11 at 01:49 PM |
here and
The different power output between the variants of the 2.0 black top in their native installations are down to the external components that are
connected to the engine - the internal bits are all the same. The externally mounted bits including inlet pipework, inlet and exhaust manifolds,
throttle bodies and ECU vary depending on the donor car, as do the ancillaries attached such as PAS and A/C pumps.
Once all this is stripped off, then engines are the same.
Paul
www.zetec-cat.co.uk
lotusmadandy
| posted on 4/1/11 at 01:51 PM |
Thanks for that Paul.
Oh and welcome to the madhouse
[Edited on 4/1/11 by lotusmadandy]
