Author: Subject: Header Tank Cap Pressure Rating
Barksavon
posted on 3/1/11 at 12:27 PM Reply With Quote
I'm going to replace my large ugly plastic header tank with an alloy one from Optimum Balance Products but need to buy a pressure rated cap as well. The ones they sell are rated between 10psi to 20psi (approx) is there a set pressure for the expansion tank cap on a 2.0litre Pinto engine or is it not too important which one i fit
ashg
posted on 3/1/11 at 12:45 PM Reply With Quote
think the standard pinto one is 8psi will have a look when i go out to the workshop later. i do know that a 14psi corsa one is bad as you end up like this when a hose blows off.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
