Author: Subject: Anybody know much about RB26 engines
NS Dev
posted on 8/1/11 at 08:25 PM Reply With Quote
I'm building a car at the mo which will be running an RB26DETT engine, using a DTA S80 ecu.
Anybody know if its a good idea to try and use the cam sensor as the only system trigger, bearing in mind its coil on plug ignition, or whether the crank position resolution would be too poor?
I know the early emerald (and other) systems used a dizzy based trigger, so again only one trigger pulse per 2 crank revs, but its all a bit old hat now!
Other option is a crank trigger wheel, but that would really end up on the front pulley, which is rubber damped, so would probably give slightly wandery trigger points? (prob no worse than none for 2 crank revs though I guess!)
Really thinking out loud on here, any ideas??
PSpirine
posted on 8/1/11 at 08:55 PM Reply With Quote
The cam angle sensor in the RB is cack enough as it is - I seem to remember them fluctuating at 8k RPM totally out of sync with the crank. Not sure whether this is something to do with timing belt flapping or just because the sensors are such low resolution..
You'll need a trigger wheel.
You can mount it to the solid nose of the crank, i.e. not the rubber damped pulley. I believe on the RB26's you can even do this mounting the trigger wheel behind the pulley so as not to affect belt changing etc. You only need a small billet bracket for the hall sensor as far as I recall.
Not difficult by any means, just make sure to have the crank balanced after you mount the trigger wheel to it!
NS Dev
posted on 9/1/11 at 10:46 AM Reply With Quote
engine's not coming apart so crank balance will be staying as-is, though I doubt a well-made trigger wheel will make much difference.
Will whip the front pulley off and see what's what on Monday
NS Dev
posted on 9/1/11 at 11:08 AM Reply With Quote
Reet, just had advice from DTA agent which pointed out that they have run these engines plenty of times on S series ecu's, and they even have a pre-programmed setup to use the stock Nissan sensor, which they have had no issues with.
It appears I should have read the S series manual that's sat on my desk......its all in there!!
DOH
T66
posted on 9/1/11 at 04:27 PM Reply With Quote
Originally posted by NS Dev
Reet,
My accent is clearly being absorbed at Retropower - I like...
"Al hay yee all talking Geordie, before ya knarrs it - divvent doubt us"
