pekwah1
| posted on 15/1/11 at 04:03 PM |
Ignition wiring help
Hi Guys,
So i'm at the stage to start wiring up the car. I have a RAW wiring loom that i've started routing through which includes chassis wiring
i.e. lights, switches, clocks etc, and i have a dunnel igntion only ECU for the Zetec which is on carbs.
Now the problem comes as i have no idea really on how to wire up an igntion system.
What's the simplest way of wiring up the ignition? Is there a really easy wiring diagram which shows the ignition/charging system which i might
understand?
I've had a search around the net and found a few things, but it's all greek to me...!
any help appreciated!
Regards,
lewis
| posted on 15/1/11 at 04:30 PM |
There are a few wiring diagrams on the Westfield world website that were pretty good sorry no link but easy to find.
adrianreeve
| posted on 15/1/11 at 04:31 PM |
Heres the Westfield one, pretty good as it does it one circuit at a time
http://westfield-world.com/Wiring_files/Wiring_frames.html
Adrian
Dusty
| posted on 15/1/11 at 04:42 PM |
Dunnell should provide you with a wiring diagram for their ecu and the sensors it needs. You may have to add connections for permanent live, ignition
live and earth to some sensors, throttlepot, coil and the ecu itself. But work from the Dunnell instructions for ignition/ecu.
pekwah1
| posted on 15/1/11 at 04:59 PM |
the dunnel ECU will have all the connectors on but i have no labels or diagram as i got it from another member on the site
