pekwah1
| posted on 15/1/11 at 11:36 PM |
Just realised i don't have a fuel pump!
So for a zetec silvertop on twin 40's, what should i be looking for?
i know nothing about fuel pumps.....
I'm not interested in getting a flash shiney mega pump, just something cheap and cheerful that does the job, is an ebay special worth getting,
or better off with an old rusty 2nd hand job?
big_wasa
| posted on 15/1/11 at 11:44 PM |
You want a low presure pump somthing around 2psi.
I would go for a 1000cc ish carbed bike pump on the cheap or webcon sell a huco pump for the webers at around £45 It works great, I have had two.
Check them out on ebay.
I wouldnt bother with a higher presure pump and regulator. Its more to play up and the extra bits add up in cost.
pekwah1
| posted on 15/1/11 at 11:46 PM |
yeh i figured a regulator wouldnt be necessary, just wasn't sure on the pump....
have seen the huco mentioned... might check it out.... are there any other specific ones i could look for?
matt_gsxr
| posted on 16/1/11 at 08:00 AM |
or one of those Facet pumps for carbs, slightly higher pressure than the bike ones.
tul214
| posted on 16/1/11 at 08:54 AM |
something like Facet Solid State Replacement Fuel Pump 4.5 - 7 PSI on eBay (end time 21-Jan-11 14:34:10 GMT) but I would
say that you should have a regulator too.
1.6 Raw Super6 sold
steve m
| posted on 16/1/11 at 10:42 AM |
The pump in Tul214's link is the same one im using as my main pump, and worked fine with the twin 40's
and i did not use a regulator!
I also use an austin mini pump for the reserve portion of the tank, but that was not man enough to fill the 40's at anything over half
throttle
