Author: Subject: Another Camshaft Question
Barksavon
posted on 19/1/11 at 08:40 PM Reply With Quote
Further to my recent post re camshaft timing......I'm still fiddling with my Newman cam (Fast Road) on Pinto engine. The data sheet shows valve lift to be .379 inch on both inlet and exhaust, ive checked total valve lift on in and ex valves on 2 of the cylinders (with a dti on the spring retainer cap) and it appears to vary between .425 to .445 inch which is 0.040 - 0.060 above what i think it should be.......is this difference ok??
As you may gather this is the first time ive fitted an after market camshaft and tried to accurately set the timing so any advice would be appreciated
will121
posted on 19/1/11 at 09:08 PM Reply With Quote
would think the quoted cam lift would be as measured on the actual cam lobe, what you are measuring on the actual valve is the cam lift multiplied by the ratio of the cam follow'er (if that makes sence)
if you are timing in the cam what you are generally looking for to start with is the centre of the maximum cam lift
[Edited on 19/1/11 by will121]
snapper
posted on 19/1/11 at 09:12 PM Reply With Quote
I would suspect that the smaller figure is cam lift i.e the difference between the base circle and the lobe tip.
Pinto has a ratio built in to the rockers that increases the lift at the valve.
You have 9.62mm at the cam, 11mm at the valve if you achieve 0.445
[Edited on 19/1/11 by snapper]
I eat to survive
I drink to forget
mcerd1
posted on 19/1/11 at 09:25 PM Reply With Quote
^^ what they said
If your looking for max. lift you just need to find it from both sides (ie. turning clockwise and turning anti-clockwise) then take the middle of these 2 as the max. lift (much the same as finding the true TDC)
Barksavon
posted on 19/1/11 at 10:09 PM Reply With Quote
great stuff, didnt realise it was so technical but its good stuff to learn...thanks a lot
