scudderfish
| posted on 20/1/11 at 01:32 PM |
Is my starter motor on the way out?
When I crank the engine, I get a loud clicking noise from the vicinity of the starter motor, approx 5-10 times a second. The engine turns fine and
starts, but it is disconcerting. Getting it out will be a right bugger so I wondered if anyone had any opinion before I go to that faff only to find
out it is OK. Engine is a 3.5L Rover V8
Regards,
Dave
[Edited on 20/1/11 by scudderfish]
https://vetuner.co.uk
MK9R
| posted on 20/1/11 at 01:37 PM |
battery on the way out?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
scudderfish
| posted on 20/1/11 at 01:44 PM |
Battery has a good voltage, and the engine cranks at a good speed, so I don't suspect that (yet), although if it was failing to keep the
solenoid energised I think it would make a noise like the one it does.
r1_pete
| posted on 20/1/11 at 01:51 PM |
Check the low current solenoid connection, if dirty it can intermittently release the solenoid.
Snuggs
Either faulty solenoid or bad solder connection on the solenoid.
I believe the solenoid actually has 2 coils.
1 to engage the starter and 1 to keep it engaged once the starter starts turning.
I had the same issue about a month after having my starter refurbished.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
jossey
| posted on 20/1/11 at 01:57 PM |
battery or earth.......
dave
David Johnson
Snuggs
| posted on 20/1/11 at 02:00 PM |
quote: Originally posted by scudderfish
Getting it out will be a right bugger.
A repair will probably cost between £15(solder joint) and £35(solenoid).
A brand new replacement is available on the bay of E for £65-70
RazMan
| posted on 20/1/11 at 05:06 PM |
Almost certain to be the solenoid - that the only thing that will click like that. However a flat battery will make the solenoid seem faulty but if
you say it turns over well then it is probably a dirty connection in the solenoid itself.
Raz
scudderfish
| posted on 23/1/11 at 06:30 PM |
Bugger.
I re did the connection to the solenoid (from underneath the car) and it made no real difference. To give the solenoid a proper work over, I'm
going to have to get the starter out. That probably means taking the exhaust manifold out. Just to make things more interesting it uses hex socket
bolts to mount the starter motor so my usual socket extensions can't get them, and I have no suitably sized allen keys
[Edited on 23/1/11 by scudderfish]
