steve8274
| posted on 23/1/11 at 04:17 PM |
fuel pipe
hi all
currently i am using rubber hose for fuel from tank to motorbike carbs. was thinking of switching to copper tube.
is it the 8mm stuff i require?
does it need to be specifically for fuel or will plumbers microbore tube suffice?
thanks
steve
Ben_Copeland
| posted on 23/1/11 at 04:23 PM |
Microbore is fine, 8mm is the usual.. but it depends on your fuel requirements
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 23/1/11 at 05:51 PM |
If you buy from an LPG parts shop you can get the Plastic coated copper in 6mm or 8mm bore , they usually sell in 6m lengths.
http://autogas-lpg.co.uk/24-pipes-hoses-lpg
steve8274
| posted on 25/1/11 at 09:22 PM |
thanks guys.
another question, when i connect rubber hose to copper pipe, is it ok to just use jubilee clips to secure or do i need to flare pipe like brakes?
thanks
steve
40inches
| posted on 25/1/11 at 09:47 PM |
quote: Originally posted by steve8274
thanks guys.
thanks
steve
Best to flare the ends and use fuel hose clips, like these.
| posted on 26/1/11 at 07:45 PM |
Jubilee clips on fuel hoses are not a good idea, Use the proper clips shown in the link
RazMan
| posted on 26/1/11 at 08:04 PM |
Definitely not Jubilee clips as they often cut into the hose - even some banded type will do the same if overtightened.
I now use the Mikalor spring type clips as they apply just the right amount of pressure and will not damage the hose.
Raz
SteveWalker
| posted on 26/1/11 at 08:14 PM |
If you want a flare on a copper pipe and don't have the right tool, just solder an olive on.
