Author: Subject: throttle cable to accelerator pedal connection?
daniel mason
posted on 28/1/11 at 08:36 PM Reply With Quote
i am using the throttle cable from the s2000 and the plastic mount which mounts to the front bulkhead pannel. i have drilled the pedal out to take a 6mm clevis but how do i connect the wire end to the clevis? all i have done is get the padal into position and put a connector block on the end of the wire to hold it! is there a suitable way to connect the wire to the clevis?
tomgregory2000
posted on 28/1/11 at 08:43 PM Reply With Quote
One of these
Click the link
universal self fix clevis on eBay (end time 06-Feb-11 11:31:44 GMT)
daniel mason
posted on 28/1/11 at 08:53 PM Reply With Quote
so do you rely on the grub screws to hold the wire? if so its no diffferent to a block connector! do the threads not tear a bit once tightened.
tomgregory2000
posted on 28/1/11 at 08:55 PM Reply With Quote
Mine has been fine for about 1500 miles so far
daniel mason
posted on 28/1/11 at 09:02 PM Reply With Quote
cheers mate. are these iva ok?
Davegtst
posted on 28/1/11 at 09:03 PM Reply With Quote
Mine has something similar taken out of an AA patrol's clutch cable repair kit. I also soldered the cable inside the clevis to give it a bit more strength but the grub screws should hold perfectly well.
