ashg
| posted on 30/1/11 at 01:08 AM |
The Monster Lives
Well it feels like the engine swap has taken an age but today i finally got it fired up.
the engine is a saab b204 turbo running a t25 turbo with vw golf turbo ignition coils all controlled by the latest and greatest megasquirt 3 coupled
with the additional ms3x card for fully sequential ignition and injection, all channelled through a vauxhall omega gearbox.
here is the vid
http://www.youtube.com/watch?v=66JB8Qway1Y
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
omega0684
| posted on 30/1/11 at 04:28 AM |
haha, love the thumbs up at the end!
froggy
| posted on 30/1/11 at 04:41 AM |
Big day getting it running and won't be long before that t25 gets binned for something bigger .
The 204 is a gem to tune , I run one with a big holset and apart from volvo t5 valve springs is bone stock and makes
510hp on pump fuel .
I've stuck to the Saab management as it's got some pretty good features for knock control and good maps are freely available on the Saab
forums here and in the us
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
stevegough
| posted on 30/1/11 at 08:15 AM |
that sounds sweet, Ash - should have had the garage door open, though!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
marcjagman
| posted on 30/1/11 at 08:24 AM |
Looks and sounds pretty good, how did you get the engine to mate to the gearbox?
ashg
| posted on 30/1/11 at 08:50 AM |
i simply bolted them together as they are the same pattern. when gm took over saab in 94-95 they made all the bolt patterns for the gearboxes the
same. the only real problem is the the omega had a dual mass flywheel and the saab has a standard one. there is nothing wrong with that its just
that the omega dual mass flywheel is 23mm thicker than the saab one meaning i had to make a spacer to get the clutch concentric slave cylinder and
release bearing close enough to the saab clutch for it to work.
the the 3.0 v6 omega box that i have also fits the vauxhall redtop just for those that are interested weighs 11.6kg less than a type9 and can take up
to 280nm of torque
big_wasa
| posted on 30/1/11 at 09:02 AM |
is it only the 3.0 v6 box that works ?
ashg
| posted on 30/1/11 at 09:23 AM |
nope they all do its just the others are rated for 250nm and the 3.0v6 is 280
MakeEverything
| posted on 30/1/11 at 11:18 AM |
Sounds very smooth. Great vid mate. Well done.
Kindest Regards,
Richard.
MakeEverything
| posted on 30/1/11 at 11:20 AM |
I watched it again, and it sounds as though there is a bit of flutter on the turbo. Do you have a dump valve fitted?
Kindest Regards,
Richard.
wylliezx9r
| posted on 30/1/11 at 12:00 PM |
If u take another look u can actually see the dumpvalve on the video.
George Best
flibble
| posted on 30/1/11 at 12:14 PM |
Nice going, sounds sweet
For some reason I thought the SAAB would be a pain to get running on megasquirt but yours obviously works well!
I'll probably be hasstling you for a 'how to' guide if mine won't run off the original ECU properly
MakeEverything
Aah i see it. I had it in a small window before, so didnt notice it.
Could just be the noise from that then.
Kindest Regards,
Richard.
gottabedone
| posted on 30/1/11 at 02:06 PM |
I think that we're all as chuffed as you are
