whitstella
posted on 2/2/11 at 11:08 AM |
which clutch
hi
i've got a type 9 gearbox with bell housing, but i seem to be short of the clutch arm. does this come with a complete clutch kit or have i got
to find 1 seperate????? the engine i will be using is a 2l zetec with hopefullt a 1.8l fly wheel. what clutch kit do i need and release bearing???
cheers steve
femster87
| posted on 2/2/11 at 12:02 PM |
If your using the 1.8 flywheel you would need a CCT133 release bearing and I believe the right clutch for the 1.8 zetec engine
Mr Whippy
| posted on 2/2/11 at 12:13 PM |
clutch kits do not come with the lever arm
mcerd1
| posted on 2/2/11 at 12:21 PM |
most kits come with a release bearing, it might not be the right one for you though
none of the kits come with a release arm - watch out when your looking for one they come in a couple of different lengths (the rs2000 ones for the
alloy bellhousings are longer I think)
