Author: Subject: Duratec advance curve
Nitrogeno25
posted on 17/2/11 at 03:37 PM Reply With Quote
I know that this was asked here but I could not find an aswer. Does anybody know the stock duratec advance curve?
Same for stock injectors, I could not found information about flow rate.
Thank you very much!
RazMan
posted on 17/2/11 at 03:52 PM Reply With Quote
The 2 litre uses Bosch part no 0280156154 which i think are rated at 19lb/hour
Raz
FASTdan
posted on 17/2/11 at 06:29 PM Reply With Quote
I'd be interested to know this too actually. We currently run the stock MJ Zetec map (even backed off a degree or so too). I'm sure we could get more out of it if we spent a bit of time on the advance.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
mikemph
Contributor
Posts 111
Registered 20/9/10
Location oxford
Member Is Offline
Photo Archive Go!
Building: R1 powered Haynes Roadster and MK Indy zetec turbo
posted on 17/2/11 at 10:29 PM Reply With Quote
Maybe try some mazda forums.... the duratec engine is made by mazda
or
Megasquirt forums
