Bumble
| posted on 18/2/11 at 04:13 PM |
How easy to change Diff Flange
Hi all,
How easy is it to change the diff flange on an English axle? Providing that's all that's done is there any special required in terms of
re-setting it once swapped over?
Thanks,
Matt
big_wasa
| posted on 18/2/11 at 04:19 PM |
You can in theory count the turns to undo it then do it back up by the same. Any more or less will alter the pre load on the pinion.
paulf
| posted on 18/2/11 at 05:52 PM |
I did mine by counting the number of turns, also marked the nut and end of thread and have had no problems.I did measure both flange thicknesses to
make sure it would be the same.
Paul
Bumble
| posted on 18/2/11 at 07:09 PM |
Thanks for the replies.
| posted on 19/2/11 at 11:06 AM |
How does this theory take into account any tolerance on the width of the splined part of the drive flange?
paulf
| posted on 19/2/11 at 08:34 PM |
It does not, however when I did mine I measured both flanges and found them to be within 2 thou of each other.
Paul
