BigDawgV8
| posted on 20/2/11 at 09:27 AM |
1.8 Loom with ECU and 2 litre Engine - Work??
Hi All,
Still un-decided hence the opposing questions on here at the moment.
Will a 1.8 Fiesta Zetec ecu loom work on a Mondeo 2 litre Black-top? Are they basically all the same?
Thanks again for the continued help and advice.
big_wasa
| posted on 20/2/11 at 09:36 AM |
Work yes but how well ?
spark map should be close but I would expect the 2.0 to want more juice. 130ps 1.8 map would be even closer.
| posted on 20/2/11 at 11:17 AM |
It will run, a friend of mine had a 2.0 silvertop in an Escort running on the 1.8 ECU for a while. However it certainly doesn't give the
drivability or performance that the correct ECU does.
