mads
| posted on 27/2/11 at 04:24 PM |
can you use rubber fuel hosing with high pressure fuel pumps?
yet another question... can you use rubber fuel hosing with a high pressure fuel pump? I am planning to use the R1 fuel pump which I believe (correct
me if I'm wrong) is a high pressure pump and not sure if the rubber hosing will be sufficient. Do i need to fork out for braided?
cheers,
mads
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
MakeEverything
| posted on 27/2/11 at 04:32 PM |
I wont use braided on fuel lines, as you cant see if they are perishing. A normal rubber fuel line should do you, just make sure its for fuel
injection (Pressure rated).
Kindest Regards,
Richard.
prawnabie
| posted on 27/2/11 at 04:55 PM |
Atif it has to be marked as high pressure for IVA iirc
mads
| posted on 28/2/11 at 07:14 AM |
cheers both
