Author: Subject: Help me choose a clutch cable
contaminated
posted on 27/2/11 at 05:29 PM Reply With Quote
As title chaps. Zetec with Type 9 box and comp brake pedal box (same sort of thing as OBP). Several suspects at Burtons:
http://www.burtonpower.com/parts-by-category/transmission-clutch-wheels/clutch-cables/qcc1003.html
http://www.burtonpower.com/parts-by-category/transmission-clutch-wheels/clutch-cables/qcc1045.html
http://www.burtonpower.com/parts-by-category/transmission-clutch-wheels/clutch-cables/qcc1055.html
http://www.burtonpower.com/parts-by-category/transmission-clutch-wheels/clutch-cables/qcc1148.html
Any ideas/preferences?
Dan
Tiger Super Six Independent
www.southernkitcars.com
big_wasa
posted on 27/2/11 at 05:34 PM Reply With Quote
I used one from a capri. Its like the escort one but a bit longer so you have a bigger smoother loop. It had the rubber damper but I cut that of to give more bare cable.
[Edited on 27/2/11 by big_wasa]
contaminated
posted on 27/2/11 at 05:38 PM Reply With Quote
What's the damper for then? Is that the big white bit or the blue tube?!
posted on 27/2/11 at 05:41 PM Reply With Quote
If in doubt try routing a piece of fence wire between the pedal fitting and the clutch operating lever, measure it and then get the cable accordingly. IIRC I used a Capri cable as well, my pedal box is similar and I have a type 9 box just make sure it clears everything
contaminated
posted on 27/2/11 at 05:49 PM Reply With Quote
Nice one chaps.
