Author: Subject: Help needed with understanding air and evap system
daniel mason
posted on 8/3/11 at 11:25 PM Reply With Quote
Am struggling with air/ evap system on the f20c install. I have removed air pump, air con system etc and brake boost vaccum, and am wondering what I need to do with all loose vac hoses and where to feed air idle control valve from? Cheers
[Edited on 8/3/11 by daniel mason]
[Edited on 9/3/11 by daniel mason]
franky
posted on 9/3/11 at 11:35 AM Reply With Quote
if its anything like mine, the air pump circulates back into the exhaust manfold. I've removed this and blanked it off. The brake vac was blanked off as we're not running assisted brakes.
The air idle valve is fed from the balance pipe on on the ITB's then to the bottom of the airbox.
If it helps I can email you pics? How was it connected in the standard install?
