moorem99
| posted on 9/3/11 at 09:26 PM |
Where has my gear gone?
HELP!!!! anyone please.....
OK - I was foolish. I bought a second hand "Type 9" box that had recently been taken from a Sierra. It is a rebuild unit (from Ford) and
at the time - very presentable.
This is a short input shaft box.
This was some time ago (5 years) and I have only just got round to putting the speedo in to get it on the road this year.
The speedo drive was not working so:
Found and fitted a second hand speedo - no movement
Fitten new speedo cable - no drive to the speedo head
Fitted new Speedo Drive Gear - no drive to speedo head
This seems strange because I removed a stub of an old speedo cable that had been cut off when I fitted the gearbox.
At this time I put my finger in the hole where the plastic Speedo Drive Gear goes. Can you imagine my surprise to find that I cannot find the speedo
drive gear on the output shaft!!!!
Anyone any idea where it may have gone?
blakep82
| posted on 9/3/11 at 09:31 PM |
my guess would be it was never there since before you bought it, and the bit of cable cut off was just there to plug a hole
________________________
jacko
| posted on 9/3/11 at 09:36 PM |
Some one has removed it
you take the plug out the opposite side to where the drive goes to fit a new one
Where in the world are you
[Edited on 9/3/11 by jacko]
moorem99
| posted on 9/3/11 at 09:45 PM |
You may have just confirmed my darkest fears...
Well I replaced the small plastic gear - I noted that when I removed it that it as rubbing on something - I presume to be the output shaft.
Is it possible that the worm drive gear has shifted along the output shaft?
I suppose its back to an electronic speedo from ETB or something now...
moorem99
| posted on 9/3/11 at 09:58 PM |
I can't imagine anyone rebuilding a box only to leave out the speedo worm drive gear from the output shaft.
Oh - by the way - I'm in Brentwood - Essex.
Thanks very much for your comments
Martin
stevec
| posted on 9/3/11 at 10:09 PM |
The gear on the mainshaft is a interference fit. If it has been taken on and off a few times it is possible for it to move on the shaft and dissapear.
Or as said it may have been left off as I did with mine because I was using a speedo with a sensor on the driveshafts.
Steve.
moorem99
| posted on 9/3/11 at 10:39 PM |
Thanks Steve.
I'm now considering either taking the gearbox out or fitting an ETB speedo with the sensor on the diff.
Regards
Martin
