Author: Subject: Couple a RWD Box to a Differential??
liam.mccaffrey
posted on 10/3/11 at 01:46 PM Reply With Quote
Further to my previous post asking about high dollar transaxles linky. Is there any reason why you couldn't couple a regular RWD box directly to a rear differential?
Might be a bit longer overall but in my application it wouldn't matter, and it could potentially be a cheaper way to a high horse power drive train.
Any opinions
[Edited on 10/3/11 by liam.mccaffrey]
Build Blog
Build Photo Album
posted on 10/3/11 at 02:07 PM Reply With Quote
I see no reason why not... gear linkage might be a nuisance though!
It's Evolution Baby!
Fred W B
posted on 10/3/11 at 02:33 PM Reply With Quote
Like this?
Fred W B
apparently:
1000hp big block Chevy, 13:1 pistons. World aluminum, rectangular port heads, big valves, and roller everything inside.... cam, lifters, rockers. MSD ignition. Fuel cells.
Seats two people and has a clear Florida title. The rear suspension, half shafts, diff, and brakes are all Corvette. Trans is a special built TH-400 with reverse valve body
[Edited on 10/3/11 by Fred W B]
liam.mccaffrey
posted on 10/3/11 at 02:54 PM Reply With Quote
Fred,
That is exactly what I had in mind, with slightly lower power requirements however
Any more info or a link or something?
Build Blog
Build Photo Album
austin man
posted on 10/3/11 at 03:04 PM Reply With Quote
why not see if you can pick up a five pot audi these have transaxles I believe
snapper
posted on 10/3/11 at 04:22 PM Reply With Quote
Some sort of cushioning bush or rubber donut is recommended.
I eat to survive
I drink to forget
liam.mccaffrey
posted on 10/3/11 at 05:30 PM Reply With Quote
trouble with that is im looking at putting 600-700 HP through it
Build Blog
Build Photo Album
zilspeed
posted on 10/3/11 at 05:34 PM Reply With Quote
Regarding the car in the pic above.
Unfortunately, due to the absurdly long packaging of the engine, transmission and final drive, the seating positions and its relationship to the front wheels is all to pot.
Feet forward of the axle line is never a good idea.
The only way around it would have been to use an equally absurd wheelbase.
Or
Just use the right transaxle.
liam.mccaffrey
posted on 10/3/11 at 05:45 PM Reply With Quote
The project I had this in mind for was a merc vito with a mid mounted v8. So packaging may not be that bad
Build Blog
Build Photo Album
blakep82
posted on 10/3/11 at 05:54 PM Reply With Quote
even a short prop shaft would be alright in that kind of thing. enough room for the engine and stuff, and the axle, so why not? would be fun.
________________________
MikeR
posted on 10/3/11 at 06:14 PM Reply With Quote
(from my 30 second thinking about this - remember, i'm no engineer)
If you don't use a short prop you'll have to solid mount the diff to the gearbox. This will either then had to be flexibly mounted and any vibration taken up in the drive shafts or solidly mounted.
If you solidly mount the gearbox you'll have to solid mount the engine. Now i know bikes get away with this but i believe car engines will cause vibrational problems (but i don't understand why bikes get away with it).
blakep82
posted on 10/3/11 at 07:07 PM Reply With Quote
i guess a lot more care is taken to balance them to get them to rev twice as high as car engines. maybe not worth the hassle for car engines for the manufacturers to balance them
posted on 10/3/11 at 07:21 PM Reply With Quote
Mounting the engine/gearbox would have to be exactly in line with the diff pinion . Could you not use at the very least a UJ?? Sort of like 2 prop flanges coupled via a UJ
posted on 10/3/11 at 08:16 PM Reply With Quote
Thinking laterally
Look at the Pamther Solo II (nb Solo 2) transmision which used Sierra bits back to front it was 4x4 but RWD version could also work.
Fred W B
posted on 11/3/11 at 06:14 AM Reply With Quote
Sorry Liam, all I know is what I posted under the pic.
Fred W B
[Edited on 11/3/11 by Fred W B]
