beaver34
| posted on 13/3/11 at 08:12 PM |
Fuel line adaptor
Hi all
I need a 7mm to 5mm fuel line adaptor
Any ideas where I can get one from?
norfolkluego
| posted on 13/3/11 at 08:17 PM |
Europa stock a good range of fuel hose adaptors
norfolkluego
| posted on 13/3/11 at 08:21 PM |
Sorry, forgot the link
LinkyLinky
stevegough
| posted on 13/3/11 at 08:36 PM |
I have had two very odd fittings I needed to source -
one was fixing a Mig welding 3mm tube to a much larger line from a big bottle regulator.
The other was connecting the screw fitting on the XE fuel rail to a rubber fuel hose.
I searched around the web quite a bit, and then popped in to 'Blackpool Hydraulics' with the bits and asked them to sort it.
Both connections were done for me in double - quick time for less than a tenner.
Now, I'm not suggesting you come to Blackpool - but pretty much everywhere will have a similar place?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
| posted on 13/3/11 at 08:49 PM |
If it's for low pressure then a universal fuel filter for about a quid or so, available at any motor factor
beaver34
| posted on 13/3/11 at 08:51 PM |
It is, but i need two ands it from a filter one is going would look bait daft I think
