Author: Subject: where or how do i install a radiator fan switch?
daniel mason
posted on 16/3/11 at 09:05 PM Reply With Quote
after looking through the s2000 workshop manual i have realised that i have somehow missed out the radiator fan switch when plumbing in the cooling circuit! i have a pro alloy rad with no boss for a switch,so where do i put it into the circuit? cheers.dan!
pewe
posted on 16/3/11 at 09:14 PM Reply With Quote
CBS do an In-line water temp sender housing, their ref #INT 25- 32-38 about £15.
HTH. Cheers, Pewe
prawnabie
posted on 16/3/11 at 09:19 PM Reply With Quote
What size is your top hose, I have a digital adjustable revotec one you can have for p+p if it is suitable.
daniel mason
posted on 16/3/11 at 09:27 PM Reply With Quote
my rad outlets are 38mm but i bought 2x silicone reducers from 38-32mm and 2x 32mm alloy hose joiners! hope this helps
[Edited on 16/3/11 by daniel mason]
blakep82
posted on 17/3/11 at 12:34 PM Reply With Quote
get a threaded boss from rakeway welded into that aluminium pipe
www.rakeway.co.uk
________________________
