cloudy
| posted on 22/3/11 at 12:42 PM |
Question for anyone with a throttle blipper...
Can anyone estimate how much throttle your blip gives? I know the approx duration, but don't know how "much" to blip it - 25%? 50%
100%?
James
www.warnercars.com
minitici
| posted on 22/3/11 at 01:10 PM |
The Flatshifter pneumatic blipper I have here has a 6mm stroke and acts on the throttle shaft at a 20mm radius.
cloudy
| posted on 22/3/11 at 01:14 PM |
OK, not much then! Would estimate about 15-20 from that%? (120mm circumference, 1/4 turn range) 6mm in 30mm range
James
www.warnercars.com
hobbsy
| posted on 22/3/11 at 04:17 PM |
I thought that the blip increases with rpm as its vacuum powered from the intake and there is a greater vacuum at higher rpm (when off the throttle).
I.e. its not a fixed amount.
jeffw
| posted on 22/3/11 at 05:22 PM |
You want it to blip the throttle sufficiently to match the revs of the gear your are changing to. So typically 2K revs extra. I would guess this
would be something like 30% as this about how much I move the throttle to heel and toe.
