Daddylonglegs
| posted on 22/3/11 at 11:47 PM |
Weber Work
Well, after the advice on here, I decided to go with the Weber 32/36 DGAV for the 2.0 Pinto in the Locost and bin the 2V 28/30. I totally forgot about
Sod's Law though, came to strip the carb down a little to check/clean and discovered that both butterflies were seized solid! After around
30mins I freed off the Primary, then another 90mins and judicious use of WD40 and a pair of pipe pliers I managed to move the secondary enough to
remove the butterfly from the shaft then drifted the shaft out. Cleaned it up, refitted and it all works a treat now
No wonder this build is taking so long.....
Forgot to say why I mentioned Sod's Law, the other carb works mechanically sweet as a nut!
[Edited on 22/3/11 by Daddylonglegs]
snapper
| posted on 23/3/11 at 04:28 AM |
Yes that is the Angel of Sod having a dump in your Soufflé.
Like working on my Mondeo1 1/2 days to replace a starter motor, £54 for 300mm of pipe
I eat to survive
I drink to forget
