Krismc
| posted on 26/3/11 at 09:23 PM |
plums/ water works
here is how my zetec is plumbed, any reccomendations for changes, and what temps are peoples engines running at? At idle, in traffic and on a gentle
run?
lsdweb
| posted on 27/3/11 at 06:35 AM |
That's wrong! Outlet from the water rail should go to the top of the rad! And you should use the thermostat bypass hose.
Here are some photos of my old Zetec install
Wyn
whitestu
| posted on 27/3/11 at 09:25 AM |
My thermostat outlet goes to the top as well.
Mine runs about 75 degrees on a gentle run and goes between 85 105 when stationary as the fan comes on and off.
Stu
Krismc
| posted on 27/3/11 at 09:41 AM |
Wyn
cheers mate and the bypass hose plumed into which pipe?
lsdweb
| posted on 27/3/11 at 10:24 AM |
Main hoses - top to top, bottom to bottom (of rad).
Bottom hose from header tank to bottom hose, top hose from header tank to top point on system.
Bypass hose bypasses the thermostat to allow some water to circulate when the stat is closed. So connect it back into the top hose after the stat,
although if I remember correctly, mine was connected into the bottom hose to give a quicker warm up time (and didn't affect the running temps
even with that cr*ppy old rad!).
Regards
Wyn
[Edited on 27/3/11 by lsdweb]
Krismc
| posted on 27/3/11 at 03:59 PM |
I need a few pipes then dont i.
